1996 2.5td 4x4 - Restoration Project
cutlass
Re: Cardiff - Starting & coolant loss problems
Post by cutlass » Fri Jan 12, 2018 12:25 pm
"direction of head replacement guide"( https://youtu.be/HyCREtQPAFg https://youtu.be/BMVe84ShxAw https://youtu.be/VvdWdeK8m_E https://youtu.be/WzY1cg3Xbrw https://youtu.be/oX3d0BO0fbY https://youtu.be/SBQJTDeNXOs ) - but wery cold weather outdoor//// :( may be now delete termostat and valve in cap of cooling tank for may guardedly use car and wait spring?
Post by g8dhe » Fri Jan 12, 2018 5:29 pm
Read the error code from the ECU, the flashing light indicates that the ECU is reporting an error. http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
Post by Bob » Tue Jan 16, 2018 10:08 am
ADS, Ashton, use a contractor for recovery and have the knowledge to do the work, and further afield Allan's, Plymouth, or Ian Taylor, Stoke, are well worth talking to.
This won't be cheap, of course, so it might be worth asking Ian or Bongo Spares what they would offer for your Bongo, perhaps as deposit for a good one?
Good luck whatever you decide. [-o<
cutlass
Post by cutlass » Tue Jan 16, 2018 1:45 pm
I think that devace dont give you more info :( /// https://www.ebay.com/itm/Leak-Check-Kit ... 2689121148
Post by Bob » Tue Jan 16, 2018 11:25 pm
Fingers crossed, you might find an MoT fail which runs well.
I'm sure there's a donor out there. [-o<
Post by haydn callow » Wed Jan 17, 2018 10:56 am
Am I missing something.....why not fit a new head ?
cutlass
Post by cutlass » Wed Jan 17, 2018 3:47 pm
its you head too......but - its wery full complect and many gasket and sealer you dont will use! remove you head - check - than order parts - may be you need only heads gasket!
link at "repair gide book" - but its russian :( https://cloud.mail.ru/public/Fkuk/VmR9tAdFX https://mikrob.ru/download/file.php?id=269542
Post by teenmal » Wed Jan 17, 2018 4:16 pm
cutlass wrote: Wed Jan 17, 2018 3:47 pm its you head too......but - its wery full complect and many gasket and sealer you dont will use! remove you head - check - than order parts - may be you need only heads gasket!
Exactly,
Its Normal practice to strip down examine and order parts required.
Take Care.
Post by haydn callow » Wed Jan 17, 2018 4:58 pm
Once the old head is removed it’s worth checking the block face is flat and decking it if in any doubt
Post by haydn callow » Wed Jan 17, 2018 7:18 pm
Still worth checking the block face is flat......and......what on earth would you want to drill holes in the stat for......???
Post by haydn callow » Wed Jan 17, 2018 8:55 pm
They don’t exactly go from closed to open in a milli second...there is nothing wrong with a well maintained system.... I’m sure Mazda And every other maker have done research/homework.....no need to over complicate things......
Relax
cutlass
Post by cutlass » Wed Jan 17, 2018 9:50 pm
many people and i drill termostate too... i do it for - bottom valve termostates is not going air = because air dont delivery hot wery fast and valve termostates may dont open, when it need, wery fast too.....
cutlass
Post by cutlass » Fri Jan 19, 2018 8:10 am
at what place of block you want "skimmed"?
cutlass
Post by cutlass » Fri Jan 19, 2018 4:03 pm
NOTE! after "cut face of block" for flate - you must in all cause check and cut "head of piston" - on bongo use only one thickness (apr 1.1-1.15mm) of heads gasket and valves dont "state at flate of heads face" - valves protrude of head apr 0.7-1.0mm .....our piston must to be above "flate of block" MAX at weru small size - on my - apr 0.2-0.3 NO MORE!!!!- or pistons in higest point may strike valves when thay close :(
Post by haydn callow » Fri Jan 19, 2018 4:11 pm
I doubt it will need machine skimming....just check it and deck it.
