Coolant pipes
Re: Coolant pipes
Post by Muzorewa » Sun May 03, 2015 11:57 am
Indeed Mike, if that had gone on tour we'd have been knackered, no icecream salesman is going to sort that or know how to bleed it.
It's only about £25.00 for a genuine Mazda one and nowhere near the job the other one is so not too bad a prospect. But the corrosion is taking place in the same area as your other t-piece pipe and where you can't see it, so logic would suggest this pipe isn't far behind if you've had to have the other one replaced.
Re: Coolant pipes
Post by mikeonb4c » Sun May 03, 2015 7:08 pm
Muzorewa wrote:Indeed Mike, if that had gone on tour we'd have been knackered, no icecream salesman is going to sort that or know how to bleed it.
Advice noted Muz and thanks :-)
Distilled Waters Run Deep
Re: Coolant pipes
Post by Distilled Waters Run Deep » Thu Jul 04, 2019 10:18 pm
Just a few years on, prices have risen a bit eh? I'm very pleased to see the copper reducer job, had thought of doing something similar but was unsure that solder would hold out under the heat.
Has anyone used microbore to replicate the gearbox pipe?
Freda AFT: Haydn/Mason alarms + engine head temperature sensor.
Moto Guzzi California Jackal X reg
TheLongRoad
Re: Coolant pipes
Post by TheLongRoad » Fri Jul 05, 2019 12:56 pm
Off topic, but we've hit 10,000 views to the thread :D
2002 Friendee 2.0 ltr Petrol.
Re: Coolant pipes
Post by Bob » Fri Jul 05, 2019 5:44 pm
Who'd have thought coolant pipes could be so interesting. 8)
Re: Coolant pipes
Post by Northern Bongolow » Fri Jul 05, 2019 11:55 pm
All those views are what it's all about for me, one person does something and we all learn.
What a great club this is. =D> =D>
Re: Coolant pipes
Post by Distilled Waters Run Deep » Sat Jul 20, 2019 3:38 pm
Distilled Waters Run Deep wrote: Thu Jul 04, 2019 10:18 pm Just a few years on, prices have risen a bit eh? I'm very pleased to see the copper reducer job, had thought of doing something similar but was unsure that solder would hold out under the heat.
I'm being lazy with the gearbox pipe, light wire brush and some smoothrite and crossed fingers.
Back to the Yorkshire fittings, are they strong enough or would some 15mm pipe in the reducers be a better bet ... or would that restrict the flow too much?
