Indeed Mike, if that had gone on tour we'd have been knackered, no icecream salesman is going to sort that or know how to bleed it.
It's only about £25.00 for a genuine Mazda one and nowhere near the job the other one is so not too bad a prospect. But the corrosion is taking place in the same area as your other t-piece pipe and where you can't see it, so logic would suggest this pipe isn't far behind if you've had to have the other one replaced.
Coolant pipes
Re: Coolant pipes
Advice noted Muz and thanksMuzorewa wrote:Indeed Mike, if that had gone on tour we'd have been knackered, no icecream salesman is going to sort that or know how to bleed it.
Re: Coolant pipes
Just a few years on, prices have risen a bit eh? I'm very pleased to see the copper reducer job, had thought of doing something similar but was unsure that solder would hold out under the heat.
Has anyone used microbore to replicate the gearbox pipe?
Freda AFT: Haydn/Mason alarms + engine head temperature sensor.
Moto Guzzi California Jackal X reg
Re: Coolant pipes
Who'd have thought coolant pipes could be so interesting.
Re: Coolant pipes
All those views are what it's all about for me, one person does something and we all learn.
What a great club this is.
Re: Coolant pipes
I'm being lazy with the gearbox pipe, light wire brush and some smoothrite and crossed fingers.Distilled Waters Run Deep wrote: Thu Jul 04, 2019 10:18 pm Just a few years on, prices have risen a bit eh? I'm very pleased to see the copper reducer job, had thought of doing something similar but was unsure that solder would hold out under the heat.
Back to the Yorkshire fittings, are they strong enough or would some 15mm pipe in the reducers be a better bet ... or would that restrict the flow too much?
