Honest answer? Absolutely no idea.
There is no way of telling what temperature it is at, and don't let anbody tell you there is.
If your fans are kicking in, then then you are looking at the stat having lost control (coolant above 96 deg.C) and the fans have taken over.
However, if the fans stop after a short while (coolant temp dropped to 91deg.C), then the stat has regained control. (This is assuming that your fan switch is working properly.)
Need more information.
Did the needle drop at all after the motorway 'blast out'?
If you haven't experienced overheating/loss of coolant, then I would think, and I stress THINK, that you are OK.
