Post
by helen&tony » Mon May 05, 2008 10:23 am
Hi The GreatPretender
When I first found the problem, and on replacing the hose, I took the cap off the degass. tank (carefully), and the pressure wasn't that much - about concomitent with the lack of pressure due to hose being slightly loose and the rad. seeping. The thing that puzzles me is that the header tank and the degass. tank both have pressure caps...the radiator one clearly marked as such...I have read that the Bongo system functions in a different manner to many vehicles, but TWO pressure caps?...As there is a constant flow through the degass tank, I would have thought that the Rad. cap would impede flow....or is this to assist early coolant warm-up?
By the way, I've just checked the oil , and that's fine....in fact the engine never needs topping between services.
I was also hoping that I don't have a head gasket problem....the way I read it , it is just the rad. itself.
Thanks again....LOTS
