Reverse light bulb
Moderator: Ian
Re: Reverse light bulb
Post by Bob » Mon Mar 05, 2018 6:30 pm
Sounds ok to me, hopefully Geoff will confirm. 8)
Post by g8dhe » Mon Mar 05, 2018 8:04 pm
Umm not quite sure what is being used here, but any standard lamp to be used on a car is never going to exceed 55 Watts (Main beam headlight) legally, which means it draws 55/12= 4.6 Amps Max. a 10 Amp wire will be more than adequate, but do make sure its automotive grade insulation which is harder and more resilient than insulation used for other purposes where there isn't vibration etc. Most joints these days would be done using crimp joints but soldering is adequate as well.
Dungoisdadsbongo
Post by Dungoisdadsbongo » Mon Mar 05, 2018 8:21 pm
Thanks for your response Geoff, the light is below;
https://rover.ebay.com/rover/0/0/0?mpre ... 2756529484
So it's ok in this instance to use greater ampage wires when joining and what would you expect the reverse light wire ampage to be?
TheLongRoad
Post by TheLongRoad » Mon Mar 05, 2018 8:55 pm
Very similar to what I fitted as a reversing light on my 4x4. I used solder joint with heat shrink. The cables are automotive type of a similar guage to the existing reversing light, Being LED these don't draw a lot of current. Hope this helps.
2002 Friendee 2.0 ltr Petrol.
Post by g8dhe » Tue Mar 06, 2018 12:16 am
OK well they are each rated at 12 Watts so each lamp draws 1 Amp each so 2 Amps for the two together, and yes its fine to use a cable rated for a higher current - its actually preferable to do so! I would still stick with something rated at about 10 Amps like this http://www.vehicle-wiring-products.eu/p ... -sq-16-020
Dungoisdadsbongo
Post by Dungoisdadsbongo » Tue Mar 06, 2018 7:39 am
Thanks for spoon feeding me on this guys, I'm completely new to all this, I'm loving having a bongo and don't want to have the maintenance and adjustments to beat me!
Kind regards
TheLongRoad
Post by TheLongRoad » Tue Mar 06, 2018 1:50 pm
We all start as novices. Just keep asking and reading and you’ll get to know your Bongo.
Post by Bob » Tue Mar 06, 2018 2:12 pm
Very true, and many others learn from questions asked and answered on here, even if they choose not to post. 8)
Return to “Pimp My Bongo”
