What does it idle at when up to temperature Stuc?? Mine will tick over comfortably at around 750rpm... The cold start & AC solenoids will compensate for this when activated... Idle adjustment screw in the blue when the solenoid is activated for the cold start or AC....Northern Bongolow wrote: the strange thing is how is it working like that and what has someone done to compensate for the lack of fast idle when warming up, if they have just wound up the throttle this must use a tad more fuel. what are the revs when its first started,then when its warmed up both without the throttle peddle, and does the aircon work.
The throttle cable may have been "nipped in" to compensate (in red) if the cold start stuff has been tampered with & not working right...? Ady???
