MADE IN JAPAN
Moderator: Ian
Colin H F
Re: MADE IN JAPAN
Post by Colin H F » Thu Sep 27, 2012 4:34 pm
Not quite sure but I emailed the supplier and he told me he has " pre-downloaded the Europe GPS map into the SD card, it is our gift for free. GPS is all ready" so thats something else I've got to play with now. Colin =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D>
Re: MADE IN JAPAN
Post by g8dhe » Fri Sep 28, 2012 5:51 pm
g8dhe wrote:
Colin H F wrote:.... a solid dot but the connection to ref 98 is a hollow dot is this significant Geoff, http://www.g8dhe.net/bwm/bwmanualp.htm?1997/Page_66 Colin
Mumm, never noticed these before explanation is here;
Top right - However it wasn't a section that was translated :-( Its not a standard symbol that I have ever come across - I have a suspicion that it might mean that the order of the wiring is not as shown, i.e. electrically its the same, but the practical sequence of the order of connection may be different from the diagram. I'll see if I can search out a translation !
Right been on to my technical translator in Japan and yes my guess was right (phew!) basically if a connection is shown with a circle rather than a dot, then the order of wiring (or even its presence) may vary depending on the options (the options are the bits of wiring in dotted boxes) in the case of page 66;
The top 3 connections 97, 98 and 99 are all optional and so the wiring loom varies, hence the circle rather than a dot for the 98 connection in the middle of the three.
Colin H F
Re: MADE IN JAPAN
Post by Colin H F » Fri Sep 28, 2012 7:10 pm
Thanks Geoff, I suppose thats why the wire I am refering to isnt in the block but it has been added after to fasilitate the function but if connected what does it do Its labelled [illumination] incedently geoff what does TNS stand for
Re: MADE IN JAPAN
Post by Simon Jones » Fri Sep 28, 2012 8:07 pm
'illumination' would connect to side light circuit so the display dims at night. TNS usually refers to a relay that controls Tail-light, No plate light and Sidelights.
Colin H F
Re: MADE IN JAPAN
Post by Colin H F » Sat Sep 29, 2012 1:37 pm
cheers Simon
Colin H F
Re: MADE IN CHINA
Post by Colin H F » Tue Oct 02, 2012 12:33 pm
Update, cant seem to get to grips with the GPS sat nav, I have followed the instructions best I can as the instruction book seems to be either from a earlier model of its a general manual for their products, as the diagrams are not what's coming on my screen but the wording is. first you enter the GPS>then accept the software> then settings>then with the stylus provided you touch the screen to select the five points when done an OK comes up which you press and that's supposed to be it, but there is more instructions so how do I get to the point where I actually put in an address to navigate
Re: MADE IN JAPAN
Post by Simon Jones » Tue Oct 02, 2012 1:16 pm
That sounds like a 5-point calibration utility that will ensure the pointer moves to whether you select on the screen. Dunno, what does the Engrish manual say?
Colin H F
Re: MADE IN JAPAN
Post by Colin H F » Tue Oct 02, 2012 1:54 pm
this is the only instruction in the manual
briwy
Re: MADE IN JAPAN
Post by briwy » Tue Oct 02, 2012 2:38 pm
Looks the same as mine in which case going from turning on it will probably start up with the radio ,TV etc.
Press the Sel button in the middle at the bottom, this should bring up another screen.
Press the spanner (settings) icon bottom left.
Press the Navigation setup button, it should show a path to the nav software, something like "Storage Card\Igo.exe". If not then use the browse (folder top right) to find the exe file and select it.
Then go back from setup screen to the normal screen (little screen icon above the setup icon)
Hit the Navigation button and it should start up.
Just a thought, might be worth taking the SD card out and putting it the PC and checking what's on it, make sure the exe file is there OK.
Colin H F
Re: MADE IN JAPAN
Post by Colin H F » Tue Oct 02, 2012 4:33 pm
Spot on printed your instructions off and enlarged it [my eyes arn't what they used to be] and two minutes at the most I was planning a rout to my daughters down south cheers briwy =D> =D> =D> =D>
briwy
Re: MADE IN JAPAN
Post by briwy » Tue Oct 02, 2012 6:05 pm
Good, glad it worked OK colin
Return to “Pimp My Bongo”
