Flashing Dummy Alarm LED.
helen&tony
Re: Flashing Dummy Alarm LED.
Post by helen&tony » Fri Nov 27, 2009 3:41 pm
I believe it was a normal red LED, just flashed by the unit , maybe, but hey, that's very interesting...Can I actually fit a flashing LED to a circuit that flashes the LED itself, or would that create some problem with the electronics in the unit, or, perhaps, not even switch the circuitry within a flashing LED in time for it to work...I have to say it's intriguing
Post by g8dhe » Fri Nov 27, 2009 5:29 pm
If its a Red LED they have the lowest voltage about 1.8 v, most flashing LEDs need above 2.5v. It might work but the flashing would be all over the place, it would be OFF for the time that the unit said, then it would come on but only for the time that the LED wanted if it was longer than what the unit wanted. So you would either end up no difference at all, or with a long flash followed by a short flash.
helen&tony
Post by helen&tony » Fri Nov 27, 2009 8:45 pm
Yes...I had an inkling that's what might happen...so i'll look out for another red one- non flashing...anyway, the alarm works, and most folk over here are petrified of right hand drive, anyway....they have trouble with a left hooker as it is :lol: :lol: :lol: :lol: :lol: :lol:
Thanks so much for your help...all is now clear
andy caff
Post by andy caff » Thu Dec 03, 2009 6:47 am
before i fitted my alarm i bought a flashing led from my local car shop fitted attached a 9v smoke alarm battery to it ,drilled a small hole in the ash tray in centre console poped the led in the hole the battery in the ash tray job a good un still got it in now battery lasts for months , if the flashin distracts you just open ash tray and disconnect :D
David Edwards
Post by David Edwards » Thu Dec 03, 2009 8:57 pm
If you really want a dummy one then look in poundland, they have them with a row of flashing led's which come on auto at dusk and go off at dawn and yes, for a pound, lol.
apole
Post by apole » Thu Dec 03, 2009 9:16 pm
Found a possible solution. Maplin do a kit for a dummy car alarm. Contains a labelled circuit board, all the bits you need with instructions. £3.99, auto senses when to come on so no external or hidden switches to worry about. Looks pretty neat.
http://www.maplin.co.uk/module.aspx?moduleno=219997
