I know Kirsty. But if you have everything transfered to your leisure battery then this will not only turn off the stero but also prevent the leisure battery from running down due to other causes such as faulty interior lights. It seems a quick fix to me and a bit more useful. all the same it will be more convenient to have a switch on the stero eventually.
Tony
Willinton Kit. (Split charge relay kit).
Re: Willinton Kit. (Split charge relay kit).
- hembramacho
Part arrived today and all fitted and working. Brilliant!hembramacho wrote:I e-mailed Martin tonight and he's sending me a replacement part ASAP. Impressive customer service!missfixit70 wrote:Or give Martin a shout, I'm sure he'll sort you out
Andrew
Andrew
