my clutch is on the floor every morning!!!!
scanner
Re: my clutch is on the floor every morning!!!!
Post by scanner » Mon Dec 01, 2008 2:02 pm
Trouble at t'Mill wrote:Yes, that's the point I was making.
Are the rubber seals used in braking systems and engines different in some way, because I was always led to believe that any contamination by engine oil of the seals used in braking systems etc. could cause them long-term damage?
A braking system is far more "safety critical" than a hydraulic clutch system and any degradation there could obviously kill you.
But just adding some engine oil in the clutch system to "get you home" isn't likely to present such a serious hazard.
Also the hydraulic fluid already present will protect the seals a fair bit - all I did was flush the system, fit a new slave cylinder and new seals in the master cylinder. As that was OK I just replaced the seals for the reason you mention - in case there were degraded.
Trouble at t'Mill
Post by Trouble at t'Mill » Mon Dec 01, 2008 7:47 pm
Cheers.
