waeco ms50 not working
Yamaha
Re: waeco ms50 not working
Post by Yamaha » Mon Aug 18, 2008 10:35 pm
robdrinky wrote:yes,switch to m.green led lights up.test b does not work and it will not engage at speeds 40 to 50 kph or higher as per instruction booklet.
I would have thought that 40 to 50km/h was too slow for it to engage?
Mike
Curator of the Bridgwater Motorbike Collection
Post by Bob » Mon Aug 18, 2008 11:08 pm
50 k/30 mph is about the minimum, certainly worth trying at, say 40 mph.
lizard
Post by lizard » Sat Sep 20, 2008 7:15 pm
Wow, fitted mine today, works a treat. I have tried with it set at 30 mph and 40 mph works great. I was amazed that it worked first time with no fiddling
Well folks, what part of the dash did you fit your control unit? I would like one of those stalk controls that Simon has.
F Zappa
scanner
Post by scanner » Sat Sep 20, 2008 7:24 pm
lizard wrote:Wow, fitted mine today, works a treat. I have tried with it set at 30 mph and 40 mph works great. I was amazed that it worked first time with no fiddling
I made up a blank to fit in the spare switch space to the right of the steering column.
It falls neatly to hand and after a while doesn't even need looking at when you use it.
lizard
Post by lizard » Sat Sep 20, 2008 7:35 pm
Thanks, bit of a b****r I will have to remove the coolant alarm led now :lol: :lol:
F Zappa
scanner
Post by scanner » Sat Sep 20, 2008 8:34 pm
lizard wrote:Thanks, bit of a b****r I will have to remove the coolant alarm led now :lol: :lol:
On mine that is now fitted on the left where the cruise control used to be before I realised I was right handed but left eyed.
robdrinky
Post by robdrinky » Sat Sep 20, 2008 9:55 pm
i fitted the cruise control panel to ours in the space to the left of the steering wheel-i tend to rest my hand on the gear shift and find its easy to operate from there.
the coolant alarm led is fitted to a blank on the right 8)
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
