DIY non invasive temperature gauge probe placement ideas...
jaylee
Re: DIY non invasive temperature gauge probe placement ideas
Post by jaylee » Tue Sep 20, 2011 1:11 pm
Right, my conclusion....
Bearing in mind one gauge is on the acc & the other running off the starter ignition.. So there is a slight delay in when they start assessing the temps..
Each separate gauge appears to follow each-other on both channels within about 1c maybe 1.5c of each-other taped to the kettle to about 86c... But i think it was fighting against the air flow running through the van with the door open?
Using a heat gun... :twisted: They all shot up past 100c to & past 125 till the high error message came up, widening the gap a couple of degrees as i played the gun on the probes still strapped to the kettle!!
What with four channels sampling temps at different times it was hard fer me to keep track of what was going on... :?
All i can say is the new unit didn't start reading sub zero temps above 75... & my unit ties the temps up when strapped to the stubs...
If someone has two units that are programmed correctly, a controlled environment & more time? Feel free! :lol:
I've had enough... :arrow:
Post by missfixit70 » Thu Sep 22, 2011 2:42 pm
My 2 replacements arrived today, worked ok when tested in a kettle boiled up, at BP one was reading 101ish, t'other was reading 104/105 ish, not the most accurate, but good enough for what I want & at least htey didn't go squiffy above 75 degrees.
Unfortunately, despite 3 remiders to the sellers, they still failed to send me the 3 metre leads that I paid for :roll: I will persevere as I am in a particularly cantackerous mood ATM :twisted:
The Great Pretender
Post by The Great Pretender » Thu Sep 22, 2011 11:42 pm
missfixit70 wrote:My 2 replacements arrived today, worked ok when tested in a kettle boiled up, at BP one was reading 101ish, t'other was reading 104/105 ish, not the most accurate, but good enough for what I want & at least htey didn't go squiffy above 75 degrees.
:lol: :lol: :lol: ............Well if the Chinese thought the Dalai Lama was a problem......................................They ain't seen nothing yet................. :shock: :shock: :lol:
To infinity and beyond
jaylee
Post by jaylee » Fri Sep 23, 2011 7:51 am
:lol: =D> =D> :lol:
I can't actually see how they can screw up the order though.... (With the probe wire length.) Unless, there is a subtle differences in the product description on the ebay page..? :?
Driver+Passengers
Post by Driver+Passengers » Wed Nov 02, 2011 11:53 pm
Back on topic, here are some DIY temperature gauge probe placement ideas...
- lid of the air cleaner (Diagram 1330C, Part 13-320)
- EGR blanking plate on the intake elbow (Diagram 1300C, Part 20-306A)
- air intake hose joints to metal pipes above the intercooler (Diagram 1311C, Part 13-332P)
- exhaust valve - metal temperature and gas temperature (Diagram 1355C, Part 13-540)
- exhaust manifold, high-temp sensor (Diagram 1310C, Part 13-450)
Matt.
Edit: I have this many sensors to play with! :twisted:
Image Image
The Great Pretender
Post by The Great Pretender » Fri Nov 04, 2011 1:07 am
Sensors each side of the intercooler would be interesting D+P. :wink:
Driver+Passengers
Post by Driver+Passengers » Fri Nov 04, 2011 1:13 pm
The Great Pretender wrote:Sensors each side of the intercooler would be interesting D+P. :wink:
Before and after removing the light coating of oil from the inside. Yes.
Image Image
bikerbob
Post by bikerbob » Sun Nov 06, 2011 8:37 pm
Have purchased a Blue LED digital thermometer from sure electronics with the DS18B20 sensor, unfortunately it don`t work accurately, surprise- surprise. They are sending a replacement unit & probe `soon`on the slow boat from china!!!!!! I now have red & blue unit display to play with (sad B,stard) hopefully driver & passenger will have some constructive- deconstructive applications to the sure issue.
Driver+Passengers
Post by Driver+Passengers » Mon Nov 07, 2011 11:12 am
bikerbob wrote:Have purchased a Blue LED digital thermometer from sure electronics with the DS18B20 sensor, unfortunately it don`t work accurately, surprise- surprise. They are sending a replacement unit & probe `soon`on the slow boat from china!!!!!! I now have red & blue unit display to play with (sad B,stard) hopefully driver & passenger will have some constructive- deconstructive applications to the sure issue.
How frustrating!!! Can you expand on "don't work accurately"? If it's got DS18B20 sensors on it, rather than NTC thermistors, I would be somewhat surprised if what you are seeing is two sensors reading wildly different temperatures, as opposed to, say, the 'old' bug where numbers 'go negative and jump about'.
Image Image
Post by mikeonb4c » Mon Nov 07, 2011 3:08 pm
Come on chaps, get on with it. I'm waiting for my HUD engine monitoring kit. We don't want this to turn into another mp3peoplecarrier custom dashboard saga, or the TV series 'Lost', which never seemed to end (bit like Downton Abbey is looking ha ha!). :shock: :lol: 8)
bikerbob
Post by bikerbob » Tue Nov 08, 2011 6:36 pm
To driver & passenger, the blue LED unit with the DS18B20 sensor did not show a reading after the decimal point throughout the temperature range, ie blue led would show a reading with the figure after the decimal point missing ie 80. c the red led running in tandem for comparison purposes with the standard probe would show 80.5c.Sure requested photographic proof which I sent to the customer services unit, their immediate response was to advise that a replacement unit would be despatched forthwith, I`m still waiting for the repalcement.Will be contacting
them tommorow to see when replacement was despatched. will advise on the outcome
bikerbob
Post by bikerbob » Sat Nov 12, 2011 1:00 pm
Have received the new unit =D> =D> =D> installed it, dont`t work, no display :x :x :x :x contacted sure they replied that it was tested prior to despatch :^o :^o :^o. sent email & photo`s showing both LED units in tandem with DS18B20 probes fitted, also photo`s of DIP switch settings, awaiting their reply but not hopeful of a successful outcome this time for another replacement [-o< [-o< [-o<
Driver+Passengers
Post by Driver+Passengers » Sat Nov 12, 2011 6:17 pm
bikerbob wrote:Have received the new unit =D> =D> =D> installed it, dont`t work, no display :x :x :x :x contacted sure they replied that it was tested prior to despatch :^o :^o :^o. sent email & photo`s showing both LED units in tandem with DS18B20 probes fitted, also photo`s of DIP switch settings, awaiting their reply but not hopeful of a successful outcome this time for another replacement [-o< [-o< [-o<
That sucks. These are essentially fairly simple devices. Sounds like their quality control really sucks!
Image Image
Driver+Passengers
Post by Driver+Passengers » Tue Nov 22, 2011 9:16 am
mikeonb4c wrote:Come on chaps, get on with it. I'm waiting for my HUD engine monitoring kit. We don't want this to turn into another mp3peoplecarrier custom dashboard saga, or the TV series 'Lost', which never seemed to end (bit like Downton Abbey is looking ha ha!). :shock: :lol: 8)
Might be a step closer with this...
http://www.bbc.co.uk/news/health-15817316
Image Image
