I'm in Wrexham, the land of riots & the kiddy fiddling boys home!
That pretty much sums up this town!
Extending the rear blind switches
Re: Extending the rear blind switches
Ahh miles away from me. Was gonna grab those cables
If it helps, I could post them to you, not sure how much the postage will be, probably around 3 quid?
Either way, it'll all work out for you in the end, it usually does.
Nice one rickster!
Problem solved Ollymuk.
Let's see what Olly says to this idea.
A fellow bongo owner has practical blinds while I dispose of junk, what a great idea, it's either that or it all goes in the bin.
If anyone needs anything else, let me know, I may have it.
Thanks Rick
I'll drop you a private message if my custom plug solution doesn't work out. The bits should be here Friday. In theory it'll work but I might just lose my *@#! trying it.
Olly
Olly
Don't worry, it'll be fine.
I have been through the same as you when doing mine, I was tempted to set fire to it at one point!
I can relate to this (I’m sure many of us can), custom build a gas locker for new conversion instead of wood cupboard from old one, measured up but found it wouldn’t quite fit through cupboard door, had to remove most of the conversion to get it in!!
