Page 2 of 3
Re: abs sensor
Posted: Fri Jul 17, 2020 8:35 pm
by willow2u
There for a daewoo and gm Cars
Re: abs sensor
Posted: Fri Jul 17, 2020 8:48 pm
Re: abs sensor
Posted: Fri Jul 17, 2020 8:58 pm
by willow2u
Like I said in earlier post ultimately cheaper on the bay
Re: abs sensor
Posted: Fri Jul 17, 2020 10:09 pm
by TallPaul
Thanks for that info, timely as my front passenger side sensor has died. Do you have a link or part no. For the connector? I can't seem to find one. Are they 'superseal' connectors?
Paul.
Re: abs sensor
Posted: Fri Jul 17, 2020 11:07 pm
by willow2u
263063123791 Is the item no on eBay are the ones I’ve bought there are some cheaper ones from China but these guys promise same day despatch
Re: abs sensor
Posted: Fri Jul 17, 2020 11:28 pm
by TallPaul
Cheers, on nights tonight so I'll order them later.
Re: abs sensor
Posted: Mon Jul 20, 2020 7:20 pm
by willow2u
Connectors arrived today bit disappointed they are slightly smaller so I ran a Stanley between the 2 pins and slid a Packer in between and it fits I’ll put a dab of silicon around the water sealing seal when it goes on for good got some photos
Re: abs sensor
Posted: Wed Jul 29, 2020 3:35 pm
by JimmyB
Hi willow2u,
Great post, Thank you. My front nearside sensor has gone and I was just wondering if the Ohmic value of the sensor matches the circa 1600 of the original or did you have to add resistors?
Re: abs sensor
Posted: Fri Jul 31, 2020 5:55 pm
by willow2u
If someone knows the original resistance I’ll check them
Re: abs sensor
Posted: Sat Aug 01, 2020 4:32 pm
by JimmyB
I checked mine to find the faulty one and all three good ones read 1640 Ohms. I'm going to fit one using your method but I was just curious to find out what the resistance was.
Ta
Re: abs sensor
Posted: Sat Aug 01, 2020 8:25 pm
by willow2u
Went to check resistance and my meter died
Re: abs sensor
Posted: Sun Aug 02, 2020 9:11 pm
by JimmyB
Isn't that just like the thing
Re: abs sensor
Posted: Fri Aug 07, 2020 7:37 am
by Kaysee_sw
Any updates on this? I need to replace a sensor asap and don't really want to pay £200 for sensor if this one is confirmed as working.
Re: abs sensor
Posted: Fri Aug 07, 2020 8:26 am
by JimmyB
My sensor has just arrived this morning and the resistance of the sensor (without cabling and connectors) is 1240 Ohms. I am going away this weekend so it will be next week before I fit it to the bongo but as an electrician I would reckon it is not going to be far off the 1640 Ohms of the others.
Will post again next week.
Re: abs sensor
Posted: Fri Aug 07, 2020 11:53 am
by willow2u
got a battery for the tester and my sensor reads 1298 i think between 800-2000 is the norm so should be ok
