Coolant alarm advice: TM1 or TM2 or something else?
Re: Coolant alarm advice: TM1 or TM2 or something else?
Post by haydn callow » Sun Mar 19, 2017 9:51 am
First thing ...recheck the coolant level when cold. It should be on the full line...if you cannot see the level very well....dip a dry stick vertically into the tank and you should show 2cms of coolant level when COLD.
please do this and report back
Clanger
Post by Clanger » Sun Mar 19, 2017 6:13 pm
Just checked the coolant level and the level, when I dipped a bamboo scewer in, measured 7cm! We have had our Bongo a while, but I am bereft of any understanding of mechanics in any shape or form :lol:
:D
Post by haydn callow » Sun Mar 19, 2017 6:25 pm
I assume you are 'dipping' the plastic tank under the bonnet which sits at the back on the right hand side. 7 cms is to much and you need to get it down to the full line when cold....use the wife's meat baster to suck some out.
Have you recently had the coolant changed?
On the front of the tank you will find the coolant alarm sensor screw....when COLD remove the screw, get her indoors to put her finger over the hole and give the screw thread a good wire brush and then replace it,,
Report back
Post by Bob » Sun Mar 19, 2017 6:53 pm
Leave the cap on when you remove the screw. :wink:
alant54
Post by alant54 » Sun Mar 19, 2017 9:31 pm
Bob wrote:Leave the cap on when you remove the screw. :wink:
Especially if it is raining...it will keep your head dry...... :roll: :oops:
Sorry ....going now.... :lol:
Alan...still plodding on....!
Post by Bob » Sun Mar 19, 2017 9:32 pm
Dohhh... ](*,) ](*,) ](*,)
Coat time, Alan. :lol:
Clanger
Post by Clanger » Mon Mar 20, 2017 1:55 pm
I think this might have fixed it [-o< I removed the leisure battery to get to the plastic coolant tank, removed the two screws (one at a time, I did not realise the coolant alarm sensors were two metal screws attached to terminals which go into the liquid coolant!) so wire brushed the screws, which were rusted at their tips, then put it all back. Managed to remove the excess coolant by use of children's straws sellotaped together, and got a lovely mouth full of coolant to take the level back down to 2cms. Handy tip to check level if you can't see it, take another straw, and dip it in and pop your finger over the end and pull it out and measure water in straw!
Now when I turn on ignition, I now get a short sharp chirp, as apposed to the long drawn out whistling wailing which I have become used to :lol: Everything now crossed, thank you all for your advise.
Post by haydn callow » Mon Mar 20, 2017 1:58 pm
If it happens again contact us for a new replacement screw!
Post by Bob » Mon Mar 20, 2017 2:02 pm
Glad you're easily sorted, and great sevice from Haydn. :D
