Changing from 2WD to 4WD
Re: Changing from 2WD to 4WD
Post by Bob » Tue Nov 01, 2016 9:58 pm
No LSD fitted, if there was you couldn't stop one wheel.
Gripped
Post by Gripped » Tue Nov 01, 2016 10:01 pm
Yep, thanks. I think I've come to that conclusion. I assumed it would be, just wanted to check. Also confirmed with the Russian website. I have a normal diff.
I am tempted to swap it out for an LSD for my off road activities !!
Post by Bob » Tue Nov 01, 2016 10:14 pm
I'd be interested to hear how you get on with that. 8)
cmm303
Post by cmm303 » Wed Nov 02, 2016 9:05 pm
Gripped wrote: So I jacked it up, put on stands. Put in neutral. Spun a wheel, the other stays still, no matter which side.
As it was safely chocked and on axle stands, I started her up. Both wheel spin, but you can stop either wheel with your foot and the other will spin.
What does this mean????
Prop shaft rotating? Put it in Park then other wheel should turn.
Chris with BertieB
Gripped
Post by Gripped » Thu Nov 03, 2016 1:51 pm
Cheers will try that - yes the prop shaft turns if either wheel is turned.
I think the diff is ok (if a little whiney) but I am still keen to put an LSD in for my occasional off road trips. Combined with snow chains, I think it will handle most conditions with proper 2 wheel grip, instead of one spinning and one stopped.
Does anyone know what the approx. price of a used LSD is for a Bongo?
cmm303
Post by cmm303 » Fri Nov 04, 2016 2:36 pm
Gripped wrote:Cheers will try that - yes the prop shaft turns if either wheel is turned.
Try giving Bongospares.co.uk a quick call.
Chris with BertieB
