the sump doesnt usually leak, check the top of the engine, the rocker cover gasket leaks and because the engine is tilted backwards it runs towards the back of the engine then down towards the gearbox front.chrisbearbongo wrote:Hi guys just wanted to give you an update on my issues.
Firstly thanks for the offer of the steelies im in north devon but would have been doable however i am fixed now.
The issue turned out to be simply i needed new break pads on my back wheels.! what had happened was due to the pad wearing it meant a part of the housing was close to the disk so was maki9ng contact at certain angles.
I never had this previously but i have only had this bongo for 6 months as my old bongo was written off outside my house by a dirty VW transporter whilst it was parked up !! but my old model had drum brakes on the rear so i never experienced it! .
Im just glad it was fixable !
I know know however i have an oil leak which looks like its the sump sealso its going back under the wrench next payday
Contact noise when turning right
