Drama free oil change
scanner
Re: Drama free oil change
Post by scanner » Sun Mar 08, 2015 8:10 pm
Some do, some don't - my Renault Master needs a service at 18,000 miles or 2 years.
Remember the Bongo service schedule was set in the 1990's and when using ordinary mineral oil. It would not be the same if it was being set now.
Post by rita » Sun Mar 08, 2015 8:26 pm
Diesel engine oil gets contaminated faster than petrol engines due to various facts mainly higher compression and combustion. They use the same principal and (tolerances)as petrol engine IE compression /oil control and scraper rings as an example.
If you change the oil on both engine at the same time and run each for a few hundred miles then drain the oils it will become apparent .The oil from the petrol engine will be a lot cleaner than the (black contaminated )oil from the diesel engine.
PS forgot to mention that the Diesel oil on these vehicles is also used as a controlled jet Piston oil cooler.
scanner
Post by scanner » Sun Mar 08, 2015 8:40 pm
rita wrote:Diesel engine oil gets contaminated faster than petrol engines due to various facts mainly higher compression and combustion. They use the same principal and (tolerances)as petrol engine IE compression /oil control and scraper rings as an example.
How does "higher compression" contaminate the oil?
Products of combustion in "blow by" can contaminate the oil BUT that is due to combustion pressure and the degree of engine wear, not "higher compression".
They are not the same thing.
Post by rita » Sun Mar 08, 2015 8:52 pm
I did say "Higher Compression AND Combustion" as in Together.
scanner
Post by scanner » Sun Mar 08, 2015 9:18 pm
So where does "Higher Compression" come into it?
the1andonly
Post by the1andonly » Sun Mar 08, 2015 9:31 pm
to add a new question
any comments on the life of motor lubricating oil (engine oil) versus the use of 50/50% rapeseed/diesel fuel
eg polymerisation, increased viscosity of oil.
another question
effect of low sulphur fuels on the life of engine oil.
Post by rita » Sun Mar 08, 2015 9:37 pm
]So where does "Higher Compression" come into it
You CANT have COMBUSTION on a Diesel engine (an old Bongo one) Without the HIGHER Compression Ratio of that of a Petrol Engine.
I am getting confused with you argument. I thought you were clued up on Oil burners.
Never mind you are never too old to learn.
:lol: :lol: :lol: :)
Post by Simon Jones » Sun Mar 08, 2015 9:45 pm
I thought this thread was about a 'drama free oil change' but it's turning out to be full of action and excitement :).
BongoBongo123
Post by BongoBongo123 » Sun Mar 08, 2015 9:53 pm
Simon Jones wrote:I thought this thread was about a 'drama free oil change' but it's turning out to be full of action and excitement :).
Ha ha I was thinking that myself. I think we would get on well !
They call me light foot.
Post by Bob » Sun Mar 08, 2015 9:54 pm
Like the Archers? 8)
scanner
Post by scanner » Sun Mar 08, 2015 9:56 pm
Bob wrote:Like the Archers? 8)
No that's gone all soggy - just like Somerset, only the rain took longer to get there.
the1andonly
Post by the1andonly » Sun Mar 08, 2015 11:09 pm
perhaps my questions didn't defuse or redirect the direction
so for another drama free thread.
started a new thread
Post by mikeonb4c » Mon Mar 09, 2015 9:33 am
Pela pump for painless oil change for me. :-)
BongoBongo123
Post by BongoBongo123 » Tue Mar 10, 2015 10:06 am
mikeonb4c wrote:Pela pump for painless oil change for me. :-)
De-luxe oil changing !
Post by Muzorewa » Tue Mar 10, 2015 3:25 pm
Indeed, but if you're going to do 50+ oil changes as we have, a pump is worth its weight in gold :wink:
