Reversing Camera
Moderator: Ian
Re: Reversing Camera
I ordered one of these but haven't got around to fitting it yet.
Do you think it would work off a switch instead of the reverse light live? I think it may be too annoying if it cut the music off every time I reverse so maybe a switched set up would suit better?
.......... cycling more.
Yep can work of a switch
Don't think its legal tho
But who will know
But who will know
I have an xtrons unit in now. Which port or socket does the
Camera connect too? I want to make sure I can connect it up
With my older model xtrons.
Thanks.
Thanks.
I think mine has a label on it saying rear view input or something along those lines, I have the instruction booklet at home I can check wire colours for you if you need it. I could even copy it and email it if required.
lThanks Stuc,looked at your picture and you seem to have the td 713 same as mine? I will have a look to see if it has
the same wires as yours. I would appreciate an email though, thanks.
Stuc, does yours have a working GPS? Mine has the option on the screen, but no inputs
for gps antennae. I have found the software for it, but without a GPS connection, no point in
using it.
using it.
No mine does not, but it has the navi button on the front, but when pressed it says "does not support gps", i think its a generic ubit which can have extras put in depending on model no.
My phone has a good GPS on it so I use that with the bluetooth on and the voice comes through the speakers.
I will try and get some pics across tonight.
Mine says the same. I like the bluetooth speaker satnav idea. I will use that
with google maps. Thanks.
Bought one last week and fitted at the weekend, well pleased
