Fresh water tank
Angie
Re: Fresh water tank
Post by Angie » Sun Apr 03, 2022 9:40 am
Hi I have done the same in a stressed day!! Where did you get all the parts from ! What do I need to buy and where do you buy from ? Also managed to add insult to Injury by putting the tap on inside x sorry pretty new to all this !
Post by Bob » Sun Apr 03, 2022 9:57 am
Hi Angie
Rotten luck, but welcome aboard.
If you know what conversion you have I would contact the company and see if they can supply a new tank, maybe fit it if required.
Failing that I'd remove it and try e bay or caravan/motorhome suppliers.
Good luck. 8)
Post by g8dhe » Sun Apr 03, 2022 12:41 pm
Otherwise it would be better to get at all the parts and find out what has been used and then find new matching container, pipes, inlet, pump and tap etc. Lots of campervan sources this is just one https://clearcutconversions.co.uk/produ ... and-waste/ but plenty of others do different sizes and parts etc.
Angie
Post by Angie » Mon Apr 04, 2022 8:46 am
Thanks guys, will go back to where is got it from, think it is going to be an expensive mistake,never mind the cost of refuelling it ! Ouch! Cheers Angie
Post by Bob » Mon Apr 04, 2022 9:52 am
Fingers crossed. 8)
