Rear heater has stopped working
Re: Rear heater has stopped working
Post by g8dhe » Wed Apr 24, 2013 12:37 pm
Yes check out the motor first, if you don't have a meter - that is the most likely cause if its been working previously.
Titan1995
Post by Titan1995 » Wed Apr 24, 2013 8:21 pm
I have spare rear heater motor if you get stuck.
judaz
Post by judaz » Fri Apr 26, 2013 6:30 pm
Got the motor out, It spins freely and works slowly with 12 volts on it.
Got the resistor out as well.
Post by g8dhe » Fri Apr 26, 2013 9:32 pm
Is this a direct feed from the battery not via the resistors etc. ? If so then there is something wrong it should go full pelt with 12 volts applied direct!
The resistors drop the voltage applied to the motor to slow it down, so if you tested it using the normal feed and controls then expect the speed it was set to - however it doesn't sound like the fuse blew which was the original problem?
judaz
Post by judaz » Sat Apr 27, 2013 9:47 am
Morning Geoff
Took the motor out cleaned and lubed it up loosely fitted it back in and changed the 30a fuse.
connected everything up except for the resistor and the fan works fine on fan speed 3 but not 1 or 2, which i think is right as there is no resistor connected?
Connected the rersistor back and fan still works fine on speed 3 but speed 1 and 2 does not work!
So i believe its the resistor?
I took the resistor apart and the transistor looks as though it has burnt out so i am first going to try and replace the transirtor and hope that solves the problem?
Does this sound about right to you?
thanks againg for all your advice
Post by g8dhe » Sat Apr 27, 2013 3:23 pm
Yes that sounds correct, however I suspect that the cause of the transistor blowing and the Fuse was the motor being jammed in some way, the transistor doesn't normally blow just like that and the continued blowing of the fuse on full power suggests exactly the same!
Might be worth checking that there are no odd items kicking about in the air pipes or boxes!
judaz
Post by judaz » Sat May 04, 2013 9:01 am
Hi Geoff
Just want to thank you for all your help. I fixed the rear resistor by replacing the transistor inside £7 well spent and it all works fine.
Thanks again
Daz
Post by g8dhe » Sat May 04, 2013 11:44 am
Excellent, was there any reasons discovered why they blew in the first place ?
