heart broken!
Re: heart broken!
Post by haydn callow » Wed Nov 07, 2012 12:17 pm
It the header tank was empty....you MUST bleed it again..
2newbies
Re: heart broken!
Post by 2newbies » Wed Nov 07, 2012 7:11 pm
Hi..Yes i will bleed it again.....I think the leaks comming from the water pump....I'm just pleased I had one of your low coolant alarms fitted...it certainly saved the day!.......thanks for the advice....Paul
turbodave
Re: heart broken!
Post by turbodave » Wed Nov 07, 2012 11:53 pm
Yep, after a rad replacement , my water pump went. There must be a correlation between increased efficiency of flow/temp from new rad, and old pump leaking?..or maybe not!! Dave
Velocette
Re: heart broken!
Post by Velocette » Thu Nov 08, 2012 1:30 am
turbodave wrote:Yep, after a rad replacement , my water pump went. There must be a correlation between increased efficiency of flow/temp from new rad, and old pump leaking?..or maybe not!! Dave
I think I'm right in saying that if ADS fit a rad, they fit a rad, stat pump and cambelt as a package or not at all for possibly this reason. I guess they get enough work this way and fewer comebacks.
Titan1995
Re: heart broken!
Post by Titan1995 » Thu Nov 08, 2012 9:25 am
I have coolant leak paranoia. I had a similar problem when fitting a new radiator. Well to a much lesser degree. The bottom hose would not seal well on the new rad. Replaced bottom hose,hose clips. bled system and all has been well for five months.
I also replaced both the expansion tank cap and radiator cap.
My low coolant alarm gets a little confused from cold though for the first minute or so of running. Chirps away at low volume then all is ok. I generally always check the coolant level before starting anyway.
