ZIG CF 9B
Re: ZIG CF 9B
Post by g8dhe » Sun Oct 21, 2012 4:19 pm
Not knowing what your using software wise its difficult to make a guess, it might be that your browser cache isn't seeing a change in name, however the file dates have changed, suggest you clear your cache in the browser normally Ctrl-Shift-Delete then make sure you only select "Cache" the link to the document remains the same http://www.g8dhe.net/bongo_images/zig/Z ... Manual.pdf
and the link to folder is http://www.g8dhe.net/bongo_images/zig/
If its not that then it might be that your ISP is caching results and not checking for updated file data, its been known in the past, if it persists I'll give you another link that is totally different !
mikeWalsall
Re: ZIG CF 9B
Post by mikeWalsall » Sun Oct 21, 2012 4:59 pm
This is mine ..
Re: ZIG CF 9B
Post by g8dhe » Sun Oct 21, 2012 11:02 pm
Thanks as well Mike all have a play with both of them and see what comes out best.
Colin H F
Re: ZIG CF 9B
Post by Colin H F » Mon Oct 22, 2012 11:51 am
hi Mike yours is slightly different than mine in as much as the fuse carriers on my load side are twist open and not slotted Colin
mikeWalsall
Re: ZIG CF 9B
Post by mikeWalsall » Mon Oct 22, 2012 4:52 pm
Mine is a C.F.9 .. dunno what other differences are to the C.F.9B ..
Colin H F
Re: ZIG CF 9B
Post by Colin H F » Mon Oct 22, 2012 5:40 pm
mines the same the "b" stands for bronze simples :D :D :D
Re: ZIG CF 9B
Post by g8dhe » Tue Oct 23, 2012 1:15 pm
Have you managed to download the new version Colin ?
Colin H F
Re: ZIG CF 9B
Post by Colin H F » Tue Oct 23, 2012 6:52 pm
no I havent geoff but it dont matter now iv'e done what i wanted to do thanks for your efferts
