leaky Hoses ... Coolant & ATF ? ..........Overheating !
rhino-wayne
Re: leaky Hoses ... Coolant & ATF ? ..........Overheating !
Post by rhino-wayne » Sun Jul 15, 2012 1:42 pm
jaylee wrote:
rhino-wayne wrote:
have also notice a slight smell of coolant in the cab :cry:
Hi, i don't like to cloud the waters but check the front heater matrix, or the pipes going in & out aint leaking too...?!! :idea:
The more I can check the better!.........time to search "Front heater matrix" #-o
Progress so far, drained coolant, flushed out header tank to radiator drain several times, filled up, flush out alternating between rad drain & bleed pipe, did a practice run of see saw bleeding......
Lunch break over..........get back to work Rhino! :evil:
