jaylee wrote:Hi, i don't like to cloud the waters but check the front heater matrix, or the pipes going in & out aint leaking too...?!!rhino-wayne wrote:
have also notice a slight smell of coolant in the cab![]()
The more I can check the better!.........time to search "Front heater matrix"
Progress so far, drained coolant, flushed out header tank to radiator drain several times, filled up, flush out alternating between rad drain & bleed pipe, did a practice run of see saw bleeding......
Lunch break over..........get back to work Rhino!
