engine oil
scanner
Re: engine oil
Post by scanner » Fri Jun 08, 2012 12:14 am
Driver+Passengers wrote:
P-Med wrote:In the end I went for a 0W/30 fully synthetic oil (Car Lube Triple R 0W/30) and I've just driven 4500 miles on it without any problems and without losing any oil.
Time for a change, then... :wink:
Not necessarily with a fully synth oil, as the original Mazda change interval only applies to 1990's spec straight mineral oil. Fully synthetic will last much much longer.
Driver+Passengers
Re: engine oil
Post by Driver+Passengers » Fri Jun 08, 2012 12:20 am
Fair point. I think Ady has racked up the miles too after a confident choice of oil. Muz, however, with his 40-odd oil changes has averaged pretty much bang on the 3000 mile mark.
Come to think of it... I'm overdue. :oops: #-o
Image Image
P-Med
Re: engine oil
Post by P-Med » Fri Jun 08, 2012 12:21 am
Yes, according to the 3000 miles service interval. But, this oil would probably last 20,000 miles, so I'm not really sure why it would need changing? I think I'll ask my mechanic what he thinks!
Re: engine oil
Post by Northern Bongolow » Fri Jun 08, 2012 5:39 am
P-Med wrote:Yes, according to the 3000 miles service interval. But, this oil would probably last 20,000 miles, so I'm not really sure why it would need changing? I think I'll ask my mechanic what he thinks!
=D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D>
winchman
Re: engine oil
Post by winchman » Fri Jun 08, 2012 7:31 am
I feel you should use what Mazda reccomend, the engine was possibly designed to run on mineral oil which can be difficult to find now.
I use semi synthetic as I feel fully synthetic isnt worth it in such an old engine.
scanner
Re: engine oil
Post by scanner » Fri Jun 08, 2012 10:22 am
winchman wrote:I feel you should use what Mazda reccomend, the engine was possibly designed to run on mineral oil which can be difficult to find now.
That might hold IF Mazda could have specced modern oil but didn't - it couldn't, so it couldn't.
winchman
Re: engine oil
Post by winchman » Fri Jun 08, 2012 10:25 am
Didnt think of that
Driver+Passengers
Re: engine oil
Post by Driver+Passengers » Fri Jun 08, 2012 10:47 am
I agree that higher spec'd oil should/will last longer. What about the filter?
Image Image
lazyb5
Re: engine oil
Post by lazyb5 » Fri Jun 08, 2012 12:53 pm
I'm sure it says filter change every other oil change
Re: engine oil
Post by Muzorewa » Fri Jun 08, 2012 1:03 pm
lazyb5 wrote:I'm sure it says filter change every other oil change
Indeed, so every 10,000km :wink:
David Edwards
Re: engine oil
Post by David Edwards » Sat Jun 09, 2012 9:49 am
An experienced (old) mechanic I know who is amazing with vehicles has always used and recommended Lidl's oil, he said he used to use in in germany on army vehicles, when they could get it as the germans always bought loads of the stuff, it is all he uses here now and to be fair I have used it for years, no problems at all. It is also priced good enough that does not sting when it is changed every four months or so.
lancyman
Re: engine oil
Post by lancyman » Sun Jun 17, 2012 1:48 pm
Hi all,
I just bought some 5w - 30 fully synthetic castrol
Magnetic for my 97 diesel. Is this going to be ok
To run on? It says petrol and diesels on the bottle.
Thanks.
mikexgough
Re: engine oil
Post by mikexgough » Sun Jun 17, 2012 8:58 pm
lancyman wrote:Hi all,
Thanks.
Yep that's fine..... there are plenty of oils out there now plenty good enough for Bongo's..... and labelled own brands but produced by Comma or Car Plan (Tetrosyl) - As most have said Semi Synth is great now....most of the 20,000 mile interval cars these days use Semi.....
I use semi in most of the Classics I have in but sometimes I have to grab a 20/50 mineral for certain ones..
Re: engine oil
Post by teenmal » Mon Jun 18, 2012 9:13 am
Thanks.
The stuff that we once used in the Classics was BP Visco Static,(Classic oil)
Diplomat
Re: engine oil
Post by Diplomat » Mon Jun 18, 2012 9:35 am
Only one oil describes itself as "Liquid Engineering".
That could be an important consideration. Some of the others might only be liquid technology.
Frank
They flew, I took up naturism
