factory fitted immobiliser ...flashing but no beeps
toastedfrog
Re: factory fitted immobiliser ...flashing but no beeps
Post by toastedfrog » Tue Jan 31, 2012 9:59 pm
ok ..its looking like one of the connectors in the immoblister unit is broke! any suggestions ??
Post by g8dhe » Tue Jan 31, 2012 10:35 pm
Any reason why it can't be repaired ?
jaylee
Post by jaylee » Tue Jan 31, 2012 10:41 pm
Without actually looking at it... Not yet on the suggestion front.. Can you (for the sake of security.) PM me & Geoff some pictures of the offending connector & unit..?
jaylee
Post by jaylee » Tue Jan 31, 2012 10:56 pm
I'm also wildly guessing that this dodgy connector may well be shorting out through the radio loom...? The removal of the radio may well have lessened this to an extent...? I've seen some weird stuff with these wagons....
toastedfrog
Post by toastedfrog » Tue Jan 31, 2012 11:08 pm
after much freezin out in the cold i relised i had breakdown cover ..the guy relutantly removed the immobillser unit ..snipping the wires so now i have have a running bongo with no alarm!!
gunna try and upload photo's cause im not sure how happy i am not having the immobiliser! he said something abt the wires inside the unit having snapped off the metal plate bit
toastedfrog
Post by toastedfrog » Tue Jan 31, 2012 11:14 pm
how do i upload photo's onto thread??
jaylee
Post by jaylee » Tue Jan 31, 2012 11:24 pm
toastedfrog wrote:how do i upload photo's onto thread??
This link will help... http://www.igmaynard.co.uk/bongo/forum/ ... =42&t=9285
toastedfrog wrote:after much freezin out in the cold i relised i had breakdown cover ..the guy relutantly removed the immobillser unit ..snipping the wires so now i have have a running bongo with no alarm!!
Look on the bright side..... No one will go after yer radio...!?!!!! :wink:
toastedfrog
Post by toastedfrog » Tue Jan 31, 2012 11:35 pm
thanks for the link !
haha tht is a very good point ...at the minute lol they'd soon bring it back :)
jaylee
Post by jaylee » Tue Jan 31, 2012 11:47 pm
toastedfrog wrote:he said something abt the wires inside the unit having snapped off the metal plate bit
I'm thinking from the description, either a wire off the loom has come away from a spade style connector in socket to the unit...? Or something has come undone on a PCB connected to what the loom should plug into???? I could totally be wrong.... :?
toastedfrog
Post by toastedfrog » Tue Jan 31, 2012 11:48 pm
http://s1053.photobucket.com/albums/s472/toastedfrog/
hope this works !!!
the broken connection is the one on the right the guy said
jaylee
Post by jaylee » Tue Jan 31, 2012 11:54 pm
toastedfrog wrote:http://s1053.photobucket.com/albums/s472/toastedfrog/
hope this works !!!
Works a treat..! But, am i right in thinking its broke behind the unit under the dash..???? :?
toastedfrog
Post by toastedfrog » Wed Feb 01, 2012 12:11 am
well it is now!! ..the unit was still flashin ..up until it breaking i was finding i had to gently push the key towards the top to get it to beep ..so think its more to do with the connection
321Away
Post by 321Away » Wed Feb 01, 2012 9:58 am
It wont have been a factory immobiliser, if it was it would have been impossible for the recovery man to bypass it, find out the make of the unit and get the relevant parts replaced. Be aware that a few years ago, several of the security firms went bust and made it impossible to get replacements/spares, new immobiliser fitted should only be about £90 anyway
Julian
jaylee
Post by jaylee » Wed Feb 01, 2012 11:20 am
I agree with Julian... Sourcing a replacement could be a hassle...!??
You could fit a "passive" starter kill switch...? A momentary switch hidden in a location only you know... :wink:
I have read about another way regarding the use of an amp turn on wire terminal on a radio head unit instead of the momentary switch... If the radio has a removable face plate the car wont start unless its installed..! :arrow:
