headlights gone kaput
PixieAndTheMoon
Re: headlights gone kaput
Post by PixieAndTheMoon » Sun Nov 27, 2011 12:45 am
^^ See what I mean, I was quite happy in my youth and bikes to get hands on with them. those were the day's...Gunk being my perfume of choice. Perhaps I should Gunk up Bongo.....
Jo xx
Post by g8dhe » Sun Nov 27, 2011 12:42 pm
Northern Bongolow wrote: there are no relays on the inner wing on that side of the motor,
In that case its a 1995 vehicle that doesn't have the relay!
1995 version                             1997 version
I also suspect that it was found that the switches weren't up to handling the current, I was a bit surprised myself to see the Flash switch contacts handling it directly! In the later versions they added the relay for the main switch but it probably wasn't cost effective to add yet another relay to handle the Flash switch.
dave_aber
Post by dave_aber » Sun Nov 27, 2011 8:36 pm
As far as I can make out, the Main and Dip beams are still going through the stalk switch, as is the flash. All I can see the relay doing is protecting the initial rotary part of the switch, as this is operating the headlight relay, but the current to the main and dip filaments is still going through the HI / LO switch. I'm surprised that they didn't have a HI relay and a LO relay, and the flash wired to operate the HI relay as well.
Dave
Image...Image
Post by g8dhe » Sun Nov 27, 2011 10:44 pm
Agree but it does mean that the current isn't flowing when the contact makes, as the relay will take a few milliseconds to pull in and that's when the highest current will flow thru the cold lamp. But its still going to have to break the working current.
Post by Northern Bongolow » Sun Nov 27, 2011 11:10 pm
thanks for the info and the diagrams guys, i think i followed what you were saying dave :wink: .
this makes sense as i think karens is one of the oldest ones, and her bongo is too. :lol: .
we have a 95 manual and a 96 auto so will cross compare, but as usual with bongo's nothing seems straight forward with early/change over/ upgrades,as they seem to overlap by quite sometime #-o #-o .
looks like a switch upgrade/sevice.
Post by Northern Bongolow » Sun Dec 11, 2011 10:47 pm
perros huevos wrote:possible earth problem on the passenger headlight and its dragging a earth from the drivers high beam filament if you was near bolton i could take a look
chris
job sorted (i think) #-o . turned out to be the above, there were several bad connections at the rear of both bulb connector blocks, most of them old damage that had been repaired but these repaires were not made weather proof so had eventually failed, the main problem once they were all working again was as above, a bad earth bodge connection on the passy side that was knocking the drivers side out #-o :roll: .
all double checked/working.
i can confirm there was deffo no relay on this model.
thanks for all your help. =D> =D> .
perros huevos
Post by perros huevos » Mon Dec 12, 2011 10:18 pm
chris
glad you sorted it, i carry vaseline in my toollbox & people always ask what its for? i use it on all electrical connections even battery post lol
chris
karena
Post by karena » Tue Dec 13, 2011 12:21 pm
Northern Bongolow wrote: i think karens is one of the oldest ones, and her bongo is too. :lol: .
sneaked that one out didnt you
anyway thanks for fixing it and thanks all for the advice seems to be working fine now.
and by the way some-one has a very interseting birthday coming up which will put him into that older age bracket -almost a crossover model eh :lol:
Post by Northern Bongolow » Tue Dec 13, 2011 3:41 pm
:oops: :oops: :oops: .
lots of christmas kisses (grovel grovel). :)
karena
Post by karena » Tue Dec 13, 2011 10:10 pm
might have to hold you too that xxx
blobber
Post by blobber » Tue Dec 13, 2011 11:30 pm
Was going to make comment on Karens being an older one and vaseline, but thought better of it. [-X [-X [-o< [-o<
Alan & Dot
Yes sir, I can Bongo !!
karena
Post by karena » Wed Dec 14, 2011 1:20 pm
:shock: you are going to need to say more prayers than that :lol:
