Page 2 of 2
				Re: Illuminated Ignition Switch
				Posted: Thu Apr 28, 2011 8:58 pm
				by jaylee
				I'll tell you what i did find when replacing the bulb.. The contacts in the holder was shorting, blowing the bulb.. I didn't realize this till the 2nd attempt with an LED which flickered..
 So i stripped the contacts out of the holder & soldered the LED into the loom!
				Posted: Fri Apr 29, 2011 12:38 pm
				by bigdaddycain
				My bongo is a 1995 vintage, so no ignition key light, but the blank is there. Daveblueozzie has put an LED in the blank of his similar vintage bongo. Not as sophisticated a set up with courtesy delays etc, but effective nonetheless! The light simply illuminates when the door opens, then extinguishes when the door is closed again. Maybe Dave will post a piccy if he has one. You can't leave a "blank" there with nowt in it!
				Posted: Fri Apr 29, 2011 1:14 pm
				by jaylee
				bigdaddycain wrote:You can't leave a "blank" there with nowt in it!
Here's one for Barrington...!
				Posted: Fri Apr 29, 2011 2:06 pm
				by bigdaddycain
				Posted: Fri Apr 29, 2011 6:01 pm
				by Barrington
				Posted: Fri Apr 29, 2011 7:42 pm
				by Triple/R
				I put one in mine last year (dark nights) the missus was struggling to get key in~it's a very limited space to get holder in~only one (of the two) courtesy cab bulbs is being used due to fitting a block of led lights in one so i wired the ignition light direct to the other & it works with the courtesy lights as it should.
				Posted: Fri Apr 29, 2011 11:00 pm
				by bigdaddycain
				Triple/R wrote:I put one in mine last year (dark nights) the missus was struggling to get key in~it's a very limited space to get holder in~only one (of the two) courtesy cab bulbs is being used due to fitting a block of led lights in one so i wired the ignition light direct to the other & it works with the courtesy lights as it should.
Nice Ray!
  I rather suspect mine will be green though (to match the bodywork)
  But then it'll look at odds with the plasma gauges which of course are blue!
