Thats looks more like the sort of thing I'd be able to fit - I'm terrified of cutting my bumper. Do you have a pic of it fitted on yours? I can't quite visualise the size or where to put itbongonaut-evv wrote:I have fitted an RDX LED lamp with flush fit surround (usually seen on Land Rovers) you can buy aftermarket ones (on Ebay) which are commonly used on KIT cars. You only need to drill 3 small holes, one for the wire and 2 for the screws so causes little damage to the bumper.
http://cgi.ebay.co.uk/RDX-LED-Rear-Fog- ... 3365970f69
rear fog light flush
Re: rear fog light flush
Does "E Mark" mean it's UK road legal and MOTable?
That would be just the solution for me, as I could have my second reversing light back (with the monster LED bulbs, too - I should be able to see something at last).
 P***AHO - "Hoptoad" - 1997 2.5TD
2WD - AFT - DIY mid conversion
Now you wouldn't! Those recessed rectangular ones look tops IMHObigdaddycain wrote:Ah very good!I'd have used something similar myself if i'd known about them before i chopped my bumper up!
				lpgimports
All personal opinions but the flush fit ones look more OE to me.
E marked is required to meet conditions and build regs so a must for an IVA test as is a switch which has the correct rear fog symbol, so the little round switches with a red dot are not ok for an IVA. For an MOT you are likely to get away with anything that is roughly off centre to the right and shines bright red and has a switch with a warning lamp...
There are two different versions the true flush fit which is a two piece model with a surround and then the lamp and housing. There is an easy fit version which has the frame and housing in one and mounts from the outside and the red lenses protrudes about 8MM and look garbage....
Paul
Paul
http://WWW.NEWACRECARS.COM  IMPORTERS
				bongonaut-evv
I would but dont know how to add a picture I tried using the Img tool but did not know how to upload the picture.Thats looks more like the sort of thing I'd be able to fit - I'm terrified of cutting my bumper. Do you have a pic of it fitted on yours? I can't quite visualise the size or where to put it
There are several flush fit fog lights available, a quick search on EBay found these. As Paul said, some are more 'flush' than others, so some will protrude slightly from the bumper.Does "E Mark" mean it's UK road legal and MOTable?
As your Bongo is already UK registered, to be MOT legal, you'll need a switch (on the dash) that illuminates when the rear fog light is on. You can pick these up pretty cheaply from most car accessory shops.
There's guidance on this link that tells you what you need to do, to upload a photo to the forum.bongonaut-evv wrote:I would but dont know how to add a picture I tried using the Img tool but did not know how to upload the picture.Thats looks more like the sort of thing I'd be able to fit - I'm terrified of cutting my bumper. Do you have a pic of it fitted on yours? I can't quite visualise the size or where to put it
				bongonaut-evv
LoopyLoo wrote:Thats looks more like the sort of thing I'd be able to fit - I'm terrified of cutting my bumper. Do you have a pic of it fitted on yours? I can't quite visualise the size or where to put itbongonaut-evv wrote:I have fitted an RDX LED lamp with flush fit surround (usually seen on Land Rovers) you can buy aftermarket ones (on Ebay) which are commonly used on KIT cars. You only need to drill 3 small holes, one for the wire and 2 for the screws so causes little damage to the bumper.
It does stick out a liitle from the rear bumper but the led ones are narrower the the standard bulb type, plus if you fit a standard bulb type you need a larger hole in the bumper for the bulb holder to sit into.P.S. its not very clear but there is a light covering of snow in this pic.
					Last edited by bongonaut-evv on Thu Mar 03, 2011 11:22 pm, edited 2 times in total.
				bongonaut-evv
Thanks mate!Doone wrote:There's guidance on this link that tells you what you need to do, to upload a photo to the forum.bongonaut-evv wrote:I would but dont know how to add a picture I tried using the Img tool but did not know how to upload the picture.Thats looks more like the sort of thing I'd be able to fit - I'm terrified of cutting my bumper. Do you have a pic of it fitted on yours? I can't quite visualise the size or where to put it
Thanks, Lorna! I'll have a look at my switch when I get the van back from getting new trousers (today? fingers crossed!), I'm actually not sure if it's illuminated. There's still time before the MOT next month...Doone wrote:As your Bongo is already UK registered, to be MOT legal, you'll need a switch (on the dash) that illuminates when the rear fog light is on. You can pick these up pretty cheaply from most car accessory shops.
