interior lights seem to have no fuse!
integraR
Re: interior lights seem to have no fuse!
Well today I pulled the 2 slow burning fuses and lights were still on and then I tried the 40a fuse under the bonnet and still on so I am off to my dads garage tomorow for a service so were going to pull some more fuses and see what happens and try and find out whats going on! I had a look behind the fuse box and theres all manor of connector blocks lose behend there so theres been modification!
when i first got mine,i removed a carrier bag full of old wiring,scotch locks,old live feeds that were still live but not taped up,from behind the fuse box area. it must have been easier to do the job right than to bodge it up that badly
good luck.
good luck.
integraR
Well no joy on any of the fuses so once back off our hols I will be tracing the wiring back from the lights to try and see whats going on and eventually I will find a way to tap into that circuit!
Now does anybody know where the loom goes for the interior lighting goes from the fusebox to the lights? I presume theres a main live feed that must then split to all the interior lights?
I guess it will be in the side where the kitchen has been built
Hope this helps...!? http://www.lushprojects.com/bongopartsm ... 1of03.html
