Wheel Shake over 60mph! I have had wheels balanced though.
fidel21
Re: Wheel Shake over 60mph! I have had wheels balanced though.
Post by fidel21 » Mon May 17, 2010 9:57 am
BAD SHAKING CONTINUES!!!
Ok, I took the bongo down to the coast at the weekend and the shake is as bad as ever the whole van is shaking am worried something is going to break and me and the family are going to end up on the roof, or worse. I have now:
  • Balanced all wheels
    Added sprigots, which fitted perfectly
    Checked power steering fluid, fine
    Check for bumps on tyres.
Now what? Ok, going to put it in the garage, it has to be one of 2 things, really cheap and badly made alloys? or something mechanical. Has anyone got any advice what I could ask my mechanic to check first?
Cheers all.
Shakey Stevens
Life in the bus lane...
Post by Northern Bongolow » Mon May 17, 2010 12:34 pm
pick a quiet piece of road, get up to wobble speed and gently apply the brakes,if it can be felt through the peddle it is likely to point to warpped discs as you say the wheels have been balanced.it could also be dirt behind the disc holding it off its mount, running out of true,remove and clean.
Post by missfixit70 » Mon May 17, 2010 2:27 pm
Badly balanced wheels? Wheel bearings? wishbones? steering rack joints?
Did you try swapping wheels around?
fidel21
Post by fidel21 » Mon May 17, 2010 2:47 pm
No I didn't try swapping wheels around. Would this maybe make a difference?
TechnoTurkey
Post by TechnoTurkey » Fri May 21, 2010 10:23 am
It would help you rule out the wheels, assuming all 4 arent out!
In my old Land Rover owning days you could get similar symptoms from a knacked prop - is yours 4x4?
Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
maxi_77
Post by maxi_77 » Sun May 23, 2010 11:45 pm
We had this problen on our 2WD Freda and after failing the MOT for wishbone problems and getting them fixed the vibration went away.
