i-alert
jaylee
Re: i-alert
Post by jaylee » Wed Jan 20, 2010 10:04 pm
haydn callow wrote:Hi, That web shop/site has been up and running 18 months now....I have the (( i-alert )) with red or green display...also the new CUBE's.
Fits in a switch blank....Simple's !!
Intrigued am i...! :?:
Re: i-alert
Post by haydn callow » Wed Jan 20, 2010 10:25 pm
Visit the webshop to get details of the CUBE
The relationship between the coolant temp and the sensor temp reading is close in that position. (there is only a few mm's of alloy between the end of the bolt and the coolant.)
However this is intended as a temp gauge and temp alarm. Once set it will warn you if the sensor temp goes above the normal for that position.
If you want to measure coolant temp....where do you want to measure it ?? I have sensors that can be placed within the coolant but not with this system.....see the CUBE if you want to measure actual coolant temp....you can put those sensors wherever you like,
Re: i-alert
Post by mikeonb4c » Wed Jan 20, 2010 11:01 pm
apole wrote:Yes it was quite easy.
Physically fitting it was very easy, pop out a switch blank and pop in the unit.
You have to wire up to switched positive and earth, plus a longer wire that goes out to the engine bay and bolts under the chosen bolt, this is a probe. Then it's a case of tidying up the wiring and all is done.
I think there is info on where to put the sensor probe on the forums.
PM me if you need any more info but it's not hard to install which is good.
Andy
How are you finding the 2-digit display Andy? From recollection of your description a while back you have to 'translate' the numbers into a 3-figure number - is that right? And doesn't it also switch between reading out temp. or battery voltage? If so, can it be made to give temp. radout by default? Also, it doesn't have an alarm facility - is that right (not I think that matters much)? I very much like the way it goes in a switch blank though - thats a very big plus :D
Re: i-alert
Post by haydn callow » Thu Jan 21, 2010 9:08 am
It reads either temp or volts...you can have it reading whichever you want (it dosn't auto switch between the two readings)...it has a "settable" high temp alarm and also can be set to switch on a fan (via a relay)
It goes up to 99c then A 1 to 9 then B 1 to 9 etc.
Once the A comes up you start to take close interest....It is actually not confusing at all.
dandemann8
Re: i-alert
Post by dandemann8 » Thu Jan 21, 2010 10:17 pm
Ok I fell for it and ordered one :D , hoping for a weekend fit depending on Mr Postman [-o< :lol: .
Will post my findings when installed.
Bongo no more........... ;-(
Re: i-alert
Post by haydn callow » Thu Jan 21, 2010 11:15 pm
You should have it to sign for in the morning.
dandemann8
Re: i-alert
Post by dandemann8 » Thu Jan 21, 2010 11:18 pm
Thanks Haydn.
P.s did you email me the instructions :?:
Re: i-alert
Post by haydn callow » Fri Jan 22, 2010 9:33 am
YEP ! did you get them ??
apole
Re: i-alert
Post by apole » Fri Jan 22, 2010 9:42 am
Hi Mike,
I know Haydn has already answered this but I am getting on with it very well, it's a useful instrument and fits very neatly which is a real bonus. It does have a high temp alarm that you can set, along with high and low voltage alarms so if you have a low or overcharge situation it tells you about that too.
It fits neatly in one of the switch blanks and there is plenty of wire provided. The unit and wiring look well made. So all in a thumbs up from me.
Andy
