missfixit70 wrote:dp bradford wrote:fargo wrote:.....My wiring is the same as this except I have 30 amp fuses. The fuse that keeps blowing is the one off the main battery.....
Mine was the same when I got it, except it had 15 amp fuses... blew the first time I ran the battery down even a bit
I replaced the relay with a heavy duty 100 amp unit I sourced from ebay, uprated the wiring between the batteries and replaced the fuses with 40 amp ones. Now it works
Dave
Bit like Triggers broom then Dave
It's the same unit you fitted, you've just replaced everything
You know it makes sense... This time next year... etc
