You know it makes sense... This time next year... etcmissfixit70 wrote:Bit like Triggers broom then Davedp bradford wrote:Mine was the same when I got it, except it had 15 amp fuses... blew the first time I ran the battery down even a bitfargo wrote:.....My wiring is the same as this except I have 30 amp fuses. The fuse that keeps blowing is the one off the main battery.....I replaced the relay with a heavy duty 100 amp unit I sourced from ebay, uprated the wiring between the batteries and replaced the fuses with 40 amp ones. Now it works
DaveIt's the same unit you fitted, you've just replaced everything
Leisure Battery Not Charging from Engine
dp bradford
Re: Leisure Battery Not Charging from Engine
fargo
Well I charged the leisure battery up and now all is well - it was very flat.
I am off and about again this weekend with a van full so I will see how it goes !
Thanks guys,
Matt.
Thanks guys,
Matt.
