Disaster?......No fifth gear
brorabongo
Re: Disaster?......No fifth gear
Post by brorabongo » Sun May 03, 2009 10:34 pm
Cheers all.
As I said I'll be on the phone to the garage first thing tomorrow. I [-o< he is not too busy just now.
ボンゴの激怒 pictures
MountainGoat
Post by MountainGoat » Sun May 03, 2009 10:34 pm
Bummer Brora. I hope that you manage to get it fixed in time for Blairgowrie without it costing you too many bawbees. I won't be the same if you can't make your usual day visit to say hello to everyone.
Tony
cheffy34
Post by cheffy34 » Sun May 03, 2009 11:17 pm
Goodluck fella won't be that bad, cheaper than the auto to fix i reckon :!: when you said the rattle goes when you press de clutch i instantly thought of your release bearing, although i've only known it as a whirring noise but i spose if it melted then anything poss :wink: are you on hols at mo :?: :D i can't believe the sun is shining in sutherland :wink: give my best to the boys if ya see any of them and spit on the trentham when you next goin past :lol: :lol:
Dar
You've Been Bongod
Post by You've Been Bongod » Mon May 04, 2009 6:38 am
phone mike @ wheelquick and tell him your simptoms and i'm sure he will tell you whats gone wrong :wink:
welsh winger
Post by welsh winger » Mon May 04, 2009 8:50 am
Years ago I had a similar problem with a Talbot, the pedal dropped a bit and it was hard to select 3rd and 4th gears, the slave cylinder only moved a few mm, turned out the thrust bearing had worn the clutch pressure plate away, it made a similar noise to the video.
hope you sort it.
Nick
Welsh Winger
brorabongo
Post by brorabongo » Mon May 04, 2009 10:08 am
Just been to the garage, (only one open today)and the up-shot is the gearbox is shot :( :(
Took me five minutes to reverse onto the road outside the house reverse as keeps on jamming, and fifth gear rattles like hell. So it's the fifth gear that gone into bits, theres bits of fifth floating effecting the other gears. We decided to get the clutch done at the same time.
I'm off now to try and find a S/h box. [-o<
Cheers.
ボンゴの激怒 pictures
MountainGoat
Post by MountainGoat » Mon May 04, 2009 11:29 am
Try phoning Wheelquick Donald. I don't know much about that new shape bongo of their's that was burnt out by vandals. but bigdaddy got a few bits out of it so you never know. Perhaps Steve will be on later to give you a few pointers. Wheelquick 01942 217800. Ask for either of the two Mikes, Snr or Jnr.
Tony
brorabongo
Post by brorabongo » Mon May 04, 2009 11:41 am
I did try phoning, but think they might be having a May day holiday? as there was no answer. It might of been that they were busy at the time. I can not get an answer from most places i've tried today.
I've used http://www.find-a-part.com/ breakers, and http://www.breakeryard.com/.
So far one reply from a breaker at "find a part" that i've used before,£385 delivered, and one from breakeryard @ £517.
I'll try phoning around tomorow.
Cheers.
ボンゴの激怒 pictures
Post by bigdaddycain » Mon May 04, 2009 3:55 pm
Hi Donald...It doesn't sound too good mate, i had similar symptoms on a car recently, and the gearbox was shot... :?
Wheelquick was indeed closed today bud...The bongo i stripped of bits was an auto. :(
I'd give mike a ring tomorrow mate, i know he has a few breakers on the go at the moment, i don't recall any of em being manual though... :?
