Goodluck fella won't be that bad, cheaper than the auto to fix i reckon
when you said the rattle goes when you press de clutch i instantly thought of your release bearing, although i've only known it as a whirring noise but i spose if it melted then anything poss
are you on hols at mo
i can't believe the sun is shining in sutherland
give my best to the boys if ya see any of them and spit on the trentham when you next goin past
Dar
