Shorted out the Glow plug rail
Grahame at work
Re: Shorted out the Glow plug rail
Post by Grahame at work » Fri Nov 21, 2008 12:02 am
hi all,
The 10 amp fuse is in the feed from the ECU to the connection between the relay and the glow plugs and is part of the sense circuit for the control of the glow plugs. The main feed is through the relay contact which is fed directly from the "1.25sq" link under the bonnet.
Hope that explains it - I'm not sure exactly how the control works - just reading the schematics.
and in answer to the question just popped up while I was typing - no the "1.25sq" link only feeds the glow plugs
Regards Grahame
Joanie2 has had a sex change and is remaned Bert
Post by g8dhe » Fri Nov 21, 2008 12:05 am
haydn callow wrote:That doesn't make sense to me...why would your "fixed" link @20 amp go and not the 10amp fuse in the fuse box...anyone any suggestions??
Was the 10Amp fuse for something else that had previously blown and you happened to chance on it and assumed that was the one that needed repairing :?:
Post by mikeonb4c » Fri Nov 21, 2008 12:33 am
Phew! A gripping tale. So glad its sorted. This forum is amazing =D> =D> =D> and take a bow, Lizard =D> =D> =D>
Post by haydn callow » Fri Nov 21, 2008 9:36 am
Silly me...couldn't have the starter running via the link co's the thing started.
Anyway all is now explained....
