sediment light on and engine died
paul9
Re: sediment light on and engine died
Post by paul9 » Mon Jul 14, 2008 11:41 am
make sure you use an inline designed for diesel,as the small paper ones have been known to collapse and cause blockages.
use a small length of to connect filter diesel pipe,instead of fitting in between existing fuel line.
connect inline to existing fuel line before main filter,attach a short length of pipe then to the inline and attach this to the main filter,this saves cutting existing pipe,and makes it easy to revert back to normal if inline becomes clogged.
also note on the inline direction of fuel flow.
these are the filters i use,but you will find them cheaper elsewhere,this is the same as mine.
http://cgi.ebay.co.uk/DIESEL-INLINE-FUE ... .m14.l1318
ronhud
Post by ronhud » Mon Jul 14, 2008 1:23 pm
Thanks Paul - that and the pic are exactly what I need
Ron
Post by mikeonb4c » Mon Jul 14, 2008 8:22 pm
Good luck Ron. We don't want you leaving the Bongo Tribe. That would make us sad :cry:
trevd01
Post by trevd01 » Mon Jul 14, 2008 8:43 pm
ronhud wrote: Trev - have you been using the biodiesel from the Huddersfield facility? I am reluctant to conclude my problem is from their fuel since it is much cheaper than ordinary diesel and if the Bongo is happy with it then its a bonus in several ways.
Sorry, no. We haven't been very far in the Bongo this summer, three weekends away on one tankful (Yorkshire Dales, Silverdale and Hayfield), still got some left! All our fuel recently has been from Morrisons in Meltham.
Last Biodiesel I used was in Belgium back end of last summer, and that was in the tank for about 3 months. I suspect that was only 15% bio anyway.
One idea is that a Bongo, being older than many vehicles I have seen filling up at the Lockwood bio pump, has more 'gunk' in the bottom of the tank from fifteen years of use to get flushed out by the biodiesel?
gingeback
Post by gingeback » Mon Jul 14, 2008 10:39 pm
just to mention sediment light and charge light being dimly on, my husband and i have posted a messae about this before, i spoke to 2 people at the garage who fitted the conversion and they said these lights were nothing to worry about they said it was common in the conversions with bongos, we bought a charge tester and tested the alternator and that seems fine, am i to worry about it?? or are they giving me a load of flannel??
Post by missfixit70 » Mon Jul 14, 2008 10:42 pm
gingeback wrote:just to mention sediment light and charge light being dimly on, my husband and i have posted a messae about this before, i spoke to 2 people at the garage who fitted the conversion and they said these lights were nothing to worry about they said it was common in the conversions with bongos, we bought a charge tester and tested the alternator and that seems fine, am i to worry about it?? or are they giving me a load of flannel??
Dimly is the key I think, to do with the LB charging on some conversions connected to the alternator rather than a voltage sensing split charge relay from the starting battery. Nothing to worry about unless they both become fully lit - then it's likely your alternator goosed.
gingeback
Post by gingeback » Wed Jul 16, 2008 8:28 am
Thanks kirsty, just needed someone to tell us this with some knowledge.. i don't trust garages much!!
