Had a v quick peek underneath mine tonight Ron. Two questions.ronhud wrote:Good luck with it Mike. I replaced a droplink on my Freda - I had a chattering noise on the nearside. When I checked by hand there was some play - checked the offside no play and no sound. Dont have ramps so jacked up and then lowered wishbone a little onto axle jack. Sprayed with plus gas a couple of times in previous days. Nuts were apparently unmoveable. Bought a set of hex sockets (as opposed to toothed sockets) which gave me a good grip on nut, got a bit of square section hollow bar from scrap yard to provide extension to socket handle and then sweated away - made appropriate grunts - and eventually the nuts moved. Discovered that the one I was removing had a locking nut on the far side and got a grip of that with a mole wrench. I used the Vectra option from the local motor factor. If you can get up on ramps it should be easier because you can use a longer 'extension' on the socket.
Ron
(1) How did you get good access to the nuts, with the wishbone in the way
(2) You suggest putting the car on ramps. But that implies you did the droplinks without removing the wheel, which seems impossible. I'd envisaged getting the car onto axle stands and just working on it like that. Anyone else care to share their experience?
V grateful for the guidance. It may take some folks 10 mins. I can assure you I'm a LOT slower than that (mostly cos I circle round the job for hours nibbling my nails and cogitating before I dive in
