Easy peasy once you've got the weight off the suspension to spread the coils on the spring. The instructions tell you to heat them up in boiling water etc so as to squeeze in. I did this but probably didn't need to as there is plenty of room to get them in.Are the spring assistors from Towsure hard to fit does anyone know?
Uprated Suspension Ideas
- dandywarhol
Oversteer is too much turning of front wheels in relation to input at the steering wheel,understeer is the opposite....DemonAV wrote:
Please explain "oversteer TGP". I don't understand.
Slight oversteer is better for crisp handling at speed
Understeer is good for predictable smooth steering....as long as you aren't in a hurry!
- daveblueozzie
I was always told the easy to remember which was which is -
With oversteer you hit the street light on the inside of the corner
With understeer you hit the street light on the outside.
I know it's actually possible to hit both street lights( or in my case, trees, piles of logs and forest drainage trenches
) , particularly with oversteer .
