Blown Fuses in Voltage Sensing Relay
izzizm,
Sorry, may have got definitions muddled...
Do you mean battery support tray by harness? If so, that's not what I was meaning!
Madmile does make up a wiring set with relay fuses etc. I've seen them on ebay @ £60, but he doesn't seem to have one listed right now.
Can't find them just now, but there are a couple of good recent threads about Leisure Battery wiring.
Some Bongos (can PM you a pic if you like) that live 'Up North' in Japan, come with 2 batteries wired in parallel to give double the current for cold starting in the winter.
Hope this makes more sense today!
bongomatic
cheers for that... interesting stuff about the 'winter battery' set-up
i understand you now
... ive been following the threads about the leisure battery fitting .. im hoping to do the whole thing for £100 tops - weld up battery tray- buy all components online etc .. although i'm sure ill be asking Madmile for some tips too
ill let you know how i get on !
cheers
Dave
cheers
Dave
hi izzizm, i purchased the kit inc 180 amp vsr relay off willington on ebay, for £65 inc delivery, hes the guy that makes the grp battery trays for the bongo on ebay.
it took me five minutes to wire it up to the batteries then another 5 to wire it through into the fuse box. he sends fitting instructions too
no worries, hope it sorts the problemMountainGoat wrote:Heavy earth strap gratefully received today, thanks Waycar8. Fitted to Bongo, then starter battery recharged and Bongo taken for a run. Now the waiting begins to see if my starter battery at long last stops loosing its charge. Watch this space.
