Oil filter change problems - please help
ros
Post by ros » Thu Jun 07, 2007 7:25 pm
Hi All,
Have just changed the oil filter on the bongo and refilled with new oil, bongo starts fine, but if revved or driven, it pees oil all over the place. Looks like it's coming from around the filter but this is on tight and the rubber seal is intact and in place.
What have we done worng?!
Thanks,
Ros.
Glynanderson
Post by Glynanderson » Thu Jun 07, 2007 7:31 pm
Might be worth checking the seal for any marks or cuts, or even to see if the old seal is still there underneath the new one.
haydn callow
Post by haydn callow » Thu Jun 07, 2007 7:59 pm
Somebody had exactly this problem about a month ago. If you go back through the topics you will find it. Think it might have been called " dumps oil on startup"
http://www.coolantalarm.co.uk
Also BMW Clocks
haydn callow
Post by haydn callow » Thu Jun 07, 2007 8:02 pm
Have just put the topic you need to the top of the list.
Also BMW Clocks
ros
Post by ros » Fri Jun 08, 2007 2:57 pm
Thanks all for your help. We got a different new oil filter and it now seems to be fine. Just about to go away in the bongo but will try to remember to update with the new type we bought next week in case others have similar problems.
Ta,
Ros.
Post by mikeonb4c » Fri Jun 08, 2007 4:17 pm
Where did the dodgy one come from Ros? Can you get your money back?
neil/di
Post by neil/di » Fri Jun 08, 2007 4:18 pm
Had exactly the same problems, the inturnal shoulder in the oil filter is to shallow and doesnt allow the oil filter to sit tight
Ros what make was your oil filter :?: ,mine was nipponparts
Neil
A Bongos is not just for christmas
