exhaust whistle
MAD DOG MURRAY
exhaust whistle
Post by MAD DOG MURRAY » Mon May 21, 2007 10:28 pm
i've just replaced the flexable part of my exhaust and now it whistles, only at high revs. have checked for leaks all ok, used pattern part any ideas.
Bumbly1
Post by Bumbly1 » Mon May 21, 2007 10:33 pm
Have you checked your manifold studs?
Harry
Post by Harry » Tue May 22, 2007 9:40 am
I'm with bumbly
Manifold studs
sounds like an old fashioned lawn mower whine?
good luck
H
http://watcherswildlife.co.uk
Veg_Ian
Post by Veg_Ian » Tue May 22, 2007 11:02 am
Except that, I'm guessing, that the whistle wasn't there before changing the flexipipe. So either a coincidence that the manifold should start to blow now or more likely something has been upset during installation of the new pipe. Did you break the connection between the turbo and downpipe? If so did you use a new gasket or gasket paste? If not, try remaking that joint with a paste type gasket.
