SEDIMENT light on dashboard
sandstone
Post by sandstone » Sat May 12, 2007 9:16 pm
Can anyone help with a description of what the red SEDIMENT light means? It has come on twice for a short time. N Reg Bongo.
bongoing-mad-simon
Post by bongoing-mad-simon » Sat May 12, 2007 9:21 pm
hi sandstone
i think it means that there is water in your fuel filter and it needs draining.
if i'm wrong someone will correct me i hope :roll:
________________
simon
I'm bongoing mad R U?
Post by bigdaddycain » Sun May 13, 2007 2:18 am
Yep, you need a new fuel filter sandstone... your not running a veg oil mix are you?
sandstone
Fuel Filter
Post by sandstone » Sun May 13, 2007 9:33 am
Many thanks for this very useful advice. I will have a look today to see it there's any water, but very soon will have new filter installed on next service. Not running Veg oil mix.
Ame
Sediment light
Post by Ame » Sun May 13, 2007 12:46 pm
My sediment light comes on with the charge light whenever i use a few revs (the only time it seems to go off is when the engine is idling).
I just fitted a brand new filter but this hasnt seemed to make a difference.
Any thoughts?
Ames (Penzance).
Chris P
Post by Chris P » Sun May 13, 2007 3:20 pm
Somewhere in the long distant past, I recall a posting that the sediment light comes on when the alternator is not charging properly (don't ask me why...).
The reason I recall it, was that I had just changed all filters when the sediment light came on a few years ago. Turns out my alternator was shot, so if you HAVE just changed the filters, get the alternator tested.
Chris
sandstone
Post by sandstone » Sun May 13, 2007 4:43 pm
Curiously the alternator warning light seems to be diode OR-ed into the Sediment light - this I have found from examining the Bongo wiring CD - it's on P54. Don't know why this should be.
The symptoms I have had are a definite ON of the SEDIMENT light on two occasions some weeks apart, but no alternator light, so hopefully it is just a blinded filter.
Ame
Post by Ame » Sun May 13, 2007 7:15 pm
Oh no!!not the alternator!
Ill get it tested.
Peg leg Pete
Post by Peg leg Pete » Sun May 13, 2007 9:11 pm
I had the same problem, it was a faulty Alternator, had to have it repaired :cry:
Image Pete
jcprice
Post by jcprice » Sun May 13, 2007 9:13 pm
I have just fitted a split charge relay kit and now the battery light is on with the sediment light so i think they must be linked somehow
Ame
Post by Ame » Tue May 15, 2007 6:44 pm
Pete how much to repair the alternator?
I see it'll be about £200-£300 for a new one!!
Peg leg Pete
Post by Peg leg Pete » Tue May 15, 2007 9:47 pm
Not sure what it cost :roll: was all done in cost of engine replacement, and I never got a itemised bill sorry :cry:
Image Pete
mvous
Post by mvous » Tue May 15, 2007 9:58 pm
Yep, t'was alternator for me too!
Replaced under warrenty with battery aswell so don't know cost.
Ame
Post by Ame » Tue May 22, 2007 7:16 pm
definitely the alternator gone for me! :cry:
Still found a local place that can get a new one for £150 so not the worst news in the world.
Thanks for all the advice.
Ames
sandstone
Post by sandstone » Sun May 27, 2007 6:52 pm
To conclude. The sediment light never came on again, but the fuel filter has been changed anyway.
I see from other threads that the switch housing on the bottom of the filter also acts as a drain. Unscrewing the switch part way apparently allows you to dump the water/sediment from the bottom of the filter bowl.
