coolant loss detection gadget
- haydn callow
- Peg leg Pete
Having suffered the dreaded overheating and engine replacement, caused by a faulty thermostat, dodgy coolant, sludge etc. I still would advice strongly that you do all the checks on hoses, coolant quality, thermostat, rad and expansion caps. When my first engine was overheating and airlock developed the coolant was forced back up to the expansion tank, so water level did not drop
Just a point to take into account and not totally rely on a water level devise
Pete- haydn callow
This device is not intended to replace routine checks and maintainance. Also it is no guarantee against engine overheating. However, at the end of the day it will detect instantly and warn you if coolant is lost and the hose the sensor is in becomes empty. I would think this would save the engine from damage in "almost" all cases of coolant loss.
- haydn callow
Lewy
