Cam / Timing Belt Settings
Matt&JoyBongling
Post by Matt&JoyBongling » Tue May 01, 2007 2:56 pm
The cam belt fact sheet provides details on how to change the belt but states;
"The following data is for the Mazda B2500 and Ford Ranger pick- ups using the WL-turbo engine. The settings are likely to be the same as the Mazda Bongo (pre-99), but don't rely on it!"
Can anyone advise whether the settings are the same for an N reg bongo and if not, what they should be?
Underground, Overground, Bongoling Free, the Bonglers of Bedford, common are we ...
Post by francophile1947 » Tue May 01, 2007 4:34 pm
Aren't there timing marks on the wheels?
Matt&JoyBongling
Post by Matt&JoyBongling » Tue May 01, 2007 5:37 pm
I would expect them but wanted to be sure in case N reg bongos have any quirks that are different from the fact sheet.
The prices I have seen quoted for the job range from £30 cash in hand to £270 +VAT for a job that takes between 30 mins and 3 hours. The more I know about the quirks etc. the more I can encourage the mechanic to keep to a reasonable price for the job :roll: .
haydn callow
Post by haydn callow » Tue May 01, 2007 6:31 pm
I would think between 60 & 90 mins to do the job. Might as well do the alternator and air con belts whilst in there.
http://www.coolantalarm.co.uk
Also BMW Clocks
Matt&JoyBongling
Post by Matt&JoyBongling » Wed May 02, 2007 1:09 pm
I have provided the belts for the alternator and aircon and have asked for them to be changed.
I'll report back with the costs and, fingers crossed, good news that it was all done without any problems in around an hour!
Matt&JoyBongling
Post by Matt&JoyBongling » Wed May 02, 2007 3:21 pm
Just had a call from the mechanic. Apparently it took 4 hours to replace the timing, alternator and air con belts. I'll be charged £175 +VAT :cry: :( :(
haydn callow
Post by haydn callow » Wed May 02, 2007 4:01 pm
£44 per hour!!! Nice work if you can get it. That's main dealer prices.
I got my timing belt with alt belts and air con belt, fuel filter changed and No 1 exaust manifold bolt drilled out and helicoiled (fiddly job) for £90 back pocket money. It should not be a 4 hour job unless perhaps they have never seen a Bongo before, even then no more than 2 hours. The guy who did mine was only useing jacks to get underneath and he said the belts were very easy to change. Don't put that garage on the list.
Also BMW Clocks
Veg_Ian
Post by Veg_Ian » Wed May 02, 2007 4:14 pm
No it's not Haydn, more like £50+ for dealer prices but extortionate all the same. It would be interesting to find out what the 'book' time is for the Bongo. I've not had a go myself but would have thought the book garage time shouldn't be any more than 2 hours if an MR2 change is 3.5 hours which requires special tools, removal of an engine mount etc etc. The Bongo should be straightforward in comparison. As you say, sounds like the mechanic has been learning on his first Bongo. Probably had time to play with all the toys as well. The words off and rip come to mind. :cry:
haydn callow
Post by haydn callow » Wed May 02, 2007 4:19 pm
It only takes about 4 hours to do a cam belt on a petrol Bongo and have you seen how complicated that is??
Also BMW Clocks
Matt&JoyBongling
Post by Matt&JoyBongling » Thu May 03, 2007 1:27 pm
Before I fall off my perch, being as sick as I am with being ripped off, I thought I would let you know that I called 2 garages on the recommended list (both within 20 miles of Bedford). One stated it was a 3 hour job and would charge £180 + VAT + parts. The second stated it would £270. :(
The job of replacing the fan, timing & aircon belts cost me £205 inc. + approx £80 for 4 belts, tensioner & spring. I was orignally informed that they would not guarantee the parts as I had supplied them but, as I handed over the cash, they stated that the work was not given any warranty at all - I guess that includes their labour as well. That made me even more :x because the owner stated that labour charges have to cover the costs incurred if they have to repair damage that they have caused.
I think that I will go and have a lie down!
haydn callow
Post by haydn callow » Thu May 03, 2007 1:34 pm
£60 per hour labour !!! STREWTH !!
Also BMW Clocks
smartmonkey
Post by smartmonkey » Thu May 03, 2007 2:02 pm
BMW and Merc charge between £95 and £110 per hour. £205 seems reasonable to me. If you want to save money just do the job yourself, thats what I do. It is the only way you know you have a good job done.
Post by francophile1947 » Thu May 03, 2007 3:03 pm
haydn callow wrote:£60 per hour labour !!! STREWTH !!
That's about normal for dealers around here, PLUS VAT of course. :shock: :shock:
Matt&JoyBongling
Post by Matt&JoyBongling » Thu May 03, 2007 5:24 pm
smartmonkey wrote: If you want to save money just do the job yourself, thats what I do. It is the only way you know you have a good job done.
I would have done it but I have been warned by several people I trust that timing belts are best left to professionals as the potential for damage if it is done incorrectly is huge and expensive. At least with a garage, there is some one to complain to / about if they do not repair the damage - but I was scr*wed in this situation as they would not guarantee work if they used bits I supplied!
dandywarhol
Post by dandywarhol » Thu May 03, 2007 11:48 pm
I sympathise M & J.
Having both run a garage and been a punter I'll sit on the fence here but.........I've been taken to the cleaners by the public before when I fitted spurious parts supplied by the owner and the part failed. It was a bitter pill to swallow but I took it on the chin to save bad PR, even though we had done nothing wrong!
Every time someone supplied parts to fit from then on I added a disclaimer that we would not guarantee the job of defective parts. You just can't win in the trade sometimes :?
