Just a quick query that may have been covered before but I just need some clarification please.
My front heater motor burned out recently and after a couple of futile attempts at repairing it I bit the bullet and bought a new one from 'Bongo Bits'. I popped it in last night (steady!) and the motor now works fine but only when the control is set on full speed. I'm sure that it worked on all other settings before the replacement - is this the resistor playing up or something else to do with the various speeds?
My fan motor failure, by the way, was caused by a rusted bottom bearing due to water ingress - I notice that the new motor has an extra drain channel on the rubber tube to prevent this common problem.
Many thanks,
Malc.
