I have read Colins posts on oil, however if you want to use 5w-30 which is suitable for diesel engines all the following are marked as API CF SL.
The CF indicate suitable for diesel use.
All are semi synthetic and can be found in motor factors
Comma Eurotch 5W30
Comma Xtech 5W-30
Comma Motrway 5W-30
Comma Premium flow 5W-30
Carlube 5W-30
Price tends to be under £20 for 5 litres which is not cheap but is a lot cheaper than most of the big name brands.
If you see oil in LIDL or WILCO and it is marked API CF and is a suitable grade 5W-30.
Then that is also a suitable oil. If it is not marked API CF I for one would not use it.
